I'm bothered by the way the inner or outer surface of each square tube is a bearing surface. Teflon buttons or something?
Good suggestion. I'd have to use the .188 wall 3 1/2 inch tube in place of the .250 wall to make room for the buttons. Hope the mild steel won't bend.
Why couldn't you have the motor at the hitch end? Could you get the gear drive inside the 3 1/2" pipe? Cut out two sides of the pipe and box the opening?
Just seemed more sturdy to keep the front tube intact, and go into the non-load bearing end of the rear tube. I may overhang the carrier a bit, and protect the motor from rain.The Teflon idea is good, though. Will let me use lighter tubing.
