Ideally the distance from your hitch to your axle would be about the length of that cargo capsule, then about 2/3 of the capsule would be in front of the axle.
Those dimensions pretty much match with the original trailer design. 2/3 forward? I thought the specs were (at least 200 lbs on the coupler.) Thanks for your help. Guess I don't need to re-invent the wheel.
