Old 04-30-2019, 10:47 AM   #45 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
You can replace the alternator with a Buick LaCrosse 20hp altermotor and serpentine belt (and possibly run it as a straight alternator while you sort out the controller and battery pack). Then you'd have regen and more power.
I've thought about that but I'm a mechanical engineer not a electrical. I'm worried about the custom controls needed to integrate the motor/generator into the van's ECU. Also anything I do has to pass smog inspection.
I've thought of using a 4wd transfer case to connect an electric motor to the drivetrain after the transmission. That setup would be essentially a stand-alone EV powertrain with manual controls.
XL hybrids has a nice system but it is $11,000.
The Following User Says Thank You to JSH For This Useful Post:
freebeard (04-30-2019)
