Old 05-02-2019, 11:19 AM   #2 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
The C-HR Hybrid isn't available in the US, where most of us are, unfortunately.
I would be hesitant to remove the spoiler; it's almost certainly there to reduce drag and rear lift. Most of it is slotted:
...probably to duct air over the rear window where it would otherwise have detached.
16" wheels are probably a good choice, especially if the wheels and/or tires are lighter--the 16" aren't even available in America.
It's probably already got iridium spark plugs (not an ecomod anyway, unless you consider longer spark plug life).
Does the C-HR Hybrid have the automatic grill shutters found on the Prius? If not, you can probably block some of the grill area.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
