Thread: Shavingcrete
Old 05-02-2019, 05:02 PM   #91 (permalink)
All Darc
The foam must be pumped into the bottom of the tank, otherwise it will not mix right.
That's why Gaia mixer have a tube that make the foam scape very close to the blades, in the bottom of the mixer.
Well, that would cut down the glare...
Something like this?
What is the cost, since it reqquires a lot of thickners and acclerators,
http://www.naturalbuildingblog.com/s...ical-concrete/
If it uses flyashes (only ???) as thickners, it may be quite ecologic.
