Old 05-08-2019, 03:48 AM   #17 (permalink)
Xist
I am caught between the discussions of battery range extenders that mathematically do not make sense, just use a generator, or the ridiculous and disproportionate amount of emissions from small engines.
Here is a drone that can sustain over two hours of flight with gasoline: https://www.quaternium.com/uav/hybrix-20/
You can't use gasoline to plant trees!
Would the small aircraft somehow pollute less?
