Great discussion
![Smile](/forum/images/smilies/smile.gif)
I have a much lighter trailer design in mind, and I am going so far as to design the wheel well area to accommodate either a pair of small 2200 pound axles or a single 5200.
My concern is the inherent bouncyness of ride with a single large tire/axle. I think a torsion with supplemental shock absorber will be a must with a big single. I have had torsions and the ride is great, but they were always tandems.
conventional spring single axles always 'launch' more than a set of tandems. More like a basketball
![Big Grin](/forum/images/smilies/biggrin.gif)
It is even more problematic when you try to cover a wide range of weight, as you are proposing. When light, even airing down the tires won't compensate for the stiffness of lightly loaded springs.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
