Old 05-09-2019, 05:15 PM   #6 (permalink)
Shaneajanderson
Redneck Ecomodder
Originally Posted by HaroldinCR View Post
Fluid was drained to proper level. No change. Feel same as you about dumping before problems. Will update when I talk with Daughter. Is it possible really dirty filter and low pressure ? Thanks
Low pressure and it would have a lot of hesitation. Low enough pressure and it wouldn't move at all. My guess would have to be the transmission itself is bad if it isn't an electrical deal. Maybe the valve body? I'm not a tranny guy (especially autotragics), but I know most trannies the valve body can be changed just by removing the oil pan.
