Hub motors just don't get it in heavier motos. You need high revving motors for direct drive or minimum 3/1 gearing. There is a new controller in beta testing right now that will do 100KW at 600A all day long.
I still have my altermotor + an AC 35 3 phase motor with a Curtis 96V 300A controller. Also have a 6 phase hub motor that should be good for the new build that is paired with 2 150V 350A controllers. That may get mounted as a mid drive mounted above the swivel of the swingarm.
The new build has a 30S3P Chevy Volt battery in it.
That Riley does not lean either.
