Originally Posted by rmccomiskie
My assumption is that the normal MPGuino hookup is one injector and the pulse width of that injector is being scaled up to represent the rest of the injectors. Right?
Basically.
Honestly though, I have no idea if that signal you have found will be accurate. We account for mechanical delay when measuring the injector pulse. I don't know if what you are looking at has accounted for that or not. You will have to carefully measure that pulse alongside the injector pulse and do some figguring if you want to be reasonably certain of the accuracy. I don't know how conditioned that signal has been, you are breaking new ground.
