Old 05-16-2019, 11:48 PM   #5 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
I assume you have LT tires that are rated 51psi--that's cold pressure, not max hot pressure.
Passing air through a radiator creates lots of drag; the less air you let through and send around the car body instead, the lower the drag and better the fuel economy. It isn't just about letting the engine warm up faster, although that is a benefit too.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
