Old 05-17-2019, 09:01 AM   #12 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
Trying to keep this moving forward. Got the glueups for the sides done. I am going to add another layer to the inside of these pieces to make it thicker at the front and add some extensions on the back to get to my desired distance. I am hoping to have it shaped and start the fiberglass this weekend.
Question:
When following the AST profiles (AST-II for the top, AST for the sides), if I encounter a bump (e.g. roughly 1/8" bump from trim on the rear of the side windows) do I need to slow up the profile immediately after that (simulating that the angle of that section is less due to the obstruction) or can I press forward following curves as if the bump did not exist? Basically I am calculating the angle of the rear of the vehicle and intercepting the templates based on this angle. If I use the glass/sheet metal the angle is different than if I use the trim.
ID:	25896   Click image for larger version
ID:	25897   Click image for larger version
The Following User Says Thank You to aardvarcus For This Useful Post:
aerohead (05-22-2019)
