Originally Posted by ToddT58
I'm currently running an experiment with three identical 40' shipping containers sitting next to each other. I painted one with "mobile home" white coating. Stuff from Home Depot, total material cost about $100. The second unit I painted with the fancy NASA-spin off "ceramic" white paint. Material cost on this was around $800! The third unit was left uncoated as a control.
The white roofs were 36 degrees F cooler than the uncoated unit. This was measured on the exterior with a laser thermometer. The interior temperatures were 16 degrees cooler for the "mobile home" white and 18 degrees cooler for the NASA-spin off white.
Important to note: I did not coat the exterior walls. I think that would make a big difference... similar to the heat gain through the windows in a car. That said, back in the '70s I put chrome film on the windows. Much cooler. I later went to a very dark window tint and it seemed cooler.
By the way, I live in Louisiana and have been driving white trucks for 20 years.
So was the chrome on the windows better, or the dark black tint?
Are you going to try painting the sides too to see what difference it makes?
