Thread: Roof Spoiler
Old 05-20-2019, 09:14 AM   #2 (permalink)
kach22i
It's hard to tell because it all depends on how it fills out or does not fill out the aerodynamic template.
I'm guessing it's this profile below - correct me if I'm wrong.
https://www.nadaguides.com/Cars/2018...0-FWD/Pictures
Guessing where that top of rear window spoiler is, I suspect it is in the airflow and interacting with the attached airflow.
Spoilers spoil the airflow, causing rolling vortexes that can pull down the layer of air above it - a good thing but it takes energy - a bad thing.
I'm not a fan of this upper location because the spoiler is not at a 60 degree angle, the angle required for creating a good vortex.
In effect this spoiler is not a spoiler, it is a flatish plate that allows for a clean release of air, but it's a clean release of air where attachment would normally be, so it's kind of a stupid location.
The effect is a larger hole in the air than without it.
Again, this needs to be verified with a template overlay - go for it Joggernot.
aerohead (08-26-2020), Joggernot (05-20-2019)
