Old 05-20-2019, 06:03 PM   #23 (permalink)
freebeard
That one's got possibilities.
3 Wheel, standard big twin trans 5sp. Electric reverse ad on. Belt from engine to trans as normal primary set up with clutch. Final drive to diff from small car in bearings. Differential enclosed by metal housing. Sprocket in place of ring gear. Half shafts out to front wheels.
Still don't get it. Is the engine/trans ahead of the front axle? Is it behind the passenger compartment? How do you get the sprocket into the differential?
If I were going to build a reverse trike, I'd use this (Lexus) drivetrain. 98lb and 68hp. 10K RPM single-speed.
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
