Old 05-21-2019, 10:46 AM   #36 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Originally Posted by ALS View Post
I've owned Turbo (2.1L and 2.3L) Volvo's from 1981-2009 and I know how to get the best mileage out of one. Rules one and two, stay out of boost, keep the RPM's under 2,500, and you'll get the best fuel mileage.
What people don't understand on modern turbo's is when the boost goes up so does the extra fuel being dumped into the cylinders. Not just to compensate for more air being pumped into the engine but that extra fuel is also used to cool the cylinders.
You might be driving a 2.3 liter Eco Boost but spool the turbo up and you might as well be driving a NA 3.5 liter as far as the amount of gas being pumped into the cylinders.
You were asking between the two which car would be better? I would go with the Mustang for the simple reason that if you planned on using the car on the highway it is far easier to swap out the rear gears for better mileage. I think it comes with 3.31 rear gears and you could swap those out easily for a set of 3.08's.
Yup. Ford for this reason. You can go to 2.73s easily on any model. Only use FRPP gears though if you do. Also, the easy part went out the window with the IRS models.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
