Old 05-22-2019, 02:26 PM   #864 (permalink)
NeilBlanchard
These are the pictures of putting the hitch on my sister-in-law's Bolt:
My brother and I did this installation, and on my own Bolt, I did it by myself.
I also bought a Curt T-One trailer light connection harness, and therein is a tale. The unit is designed for the Chevy Volt, and said that it fits a Chevy Bolt, as well. It does have to correct connectors, that T into the left and right light groups that are in the bumper of the Bolt EV.
Two problems became apparent, though. Here's my email that I sent to TorkLift:
I received the T-One connector a few days ago, and I finished installing it today. It is made for the Volt - and it is supposed to "fit" the Bolt EV; which is what I have. While it does "fit" - it has two fairly serious issues:
The location of the 12v battery in the Volt is in the back, under the floor of the hatch area (where a spare tire is often located). So the wire on the T-One that connects to the battery is roughly 3 feet long, or so. The 12v battery in the Bolt EV - is up in the front of the car, under the hood, on the driver's side - where many if not most, are located. I had to add 16 feet of 12 gauge wire to be able to connect to the positive terminal; and I needed to make 2 splices, so I could keep the 10A fuse in place.
The second issue is a bit more subtle. While the Volt is a hatchback, it's taillights are located on the body of the car. The Bolt EV is a hatchback as well - but it's main taillights / brake lights are located on the *hatch door* itself. The turn signals are located in the bumper. The issue is that by law, there have to be "alternative" tail / brake lights on the body - for when the hatch door is open. This is because, if the door is all the way open, the lights would not be visible.
So, basically, I have to open the hatch door, in order for the trailer tail / brake lights to function. The T connections on the unit do "fit" in that they plug into the left and the right side lights *on the bumper*. I don't know where to find the connectors for the lights in the hatch door - and the turn signals are in the bumper, anyway. They are probably too far away for the length of wires on the T-One unit you provided.
I hope this all is clear - if you have questions, I'd be happy to answer, if I can. I think you need to not sell this unit for the Chevy Bolt EV, and hopefully Curt can make one that does have 1) a long enough wire to reach the 12v battery, and 2) connectors AND INSTRUCTIONS to connect it properly to the Bolt EV *without* having to tow a trailer with the hatch door (slightly) open.
PaleMelanesian (05-23-2019), Xist (05-22-2019)
