Old 05-22-2019, 09:42 PM   #3 (permalink)
holypaulie
Perhaps,but don't look for anything significant.That area is in an area of flow attack,so it tends to be held against the body simply from the favorable pressure gradient there.Also,the area 'behind' it is generously radiused,allowing the flow to easily round the corner to the body sides without separation.Any air trapped where the fog lights would be,simply pools there,with the outer,active flow just skimming off it, as though it were solid.
Aerohead, thank you for your detailed reply. I forgot to add that I covered factory fog cover with thin black sheet. The factory fog light had fins just for sport looking appearance and they trapped some air. I don't care that much about look.
What do you think about front or rear bumper aero tray?
Name:	factory fog lights covers.jpg
ID:	25937   Click image for larger version
Name:	under rear bumper view right side.jpg
ID:	25938   Click image for larger version
Name:	under rear bumper view left side.jpg
The Following User Says Thank You to holypaulie For This Useful Post:
aerohead (05-25-2019)
