Old 05-22-2019, 10:16 PM   #184 (permalink)
mpg_numbers_guy
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
Now do it again, but father.
I've gotten over 100 MPG every time on my drive back home from work so far - highest is 106.6 MPG - but only 85-95 MPG on the drive in on a cold engine. Unfortunately right now, other than pizza delivery driving when I can't hypermile, all my driving is just short 6.5 mile drives to work and back.
Added some more rear underbody paneling to the Insight today.
In the picture, the front panel is one that goes from Scott's aluminum belly pan up to the downstream catalytic converter. Both that one and the dirty rear one in the back have been installed for a couple thousand miles now. The smaller piece on the left helps fill in some of the gaps, and the larger panel on the right fills in most of the poor aero there in the exhaust area. Coroplast is at least 1 1/4 inches away from any exhaust piping or muffler. I may add some aluminum sheeting if I find that it still doesn't hold up to the heat.
All panels are attached securely with zip ties in either stock holes or small holes drilled into the stock plastic underbody panels. Panels also each overlap by 1-2 inches to prevent any gaps, and Tyvek tape was used to seal up the areas where they meet. So far Tyvek tape has proven much more durable in harsh weather than duct tape.
Would it be a bad idea to extend the underbody paneling underneath the suspension components up front and in the rear?
How about the center where the catalytic converter, resonator, and more exhaust piping reside? Should I do aluminum there or coroplast? Also worried about heat being trapped if I were do add a panel there, which might mess up some stuff in the surrounding area.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
The Following User Says Thank You to mpg_numbers_guy For This Useful Post:
Ecky (06-06-2019)
