Old 05-26-2019, 02:04 PM   #23 (permalink)
Enviro
If you want to lower it then lower it.
Air dams versus belly pans would appear that belly pans are slightly better for substantially far more work, materials and time. Plus if you put a good belly pan on there it might boil the gas in the fuel tank.
The air dam gives the most benefit for the least time and materials with the least undesirable side effects.
I might just do a partial flat belly then and leave the gas tank exposed.
