Old 05-28-2019, 07:10 AM   #37 (permalink)
slowmover
90 day: 19.36 mpg (US)
Originally Posted by Tahoe_Hybrid View Post
This is LA tailgating is the name of the game... if you leave more then 15 feet you can bet someone will cut you off.. and possibly even forced to rear end them .
. A car length is not a standardized unit of measure.
I use cruse control it has Manual controls so I can deduct speed or add speed using the wheel controls..... without pressing the brake or canceling it out
I'm used to dealing with heavy traffic you are not..
I go through more traffic of every kind in a month or so than you do in a year. And in the vehicle you believe it a good idea to tailgate.
I was used to heavy traffic probably before you were born. Every major metro of this country.
You “may” survive a variety of accidents with other personal vehicles. A high percentage. You “won’t” survive most of the types of accidents created by or around big trucks (is how you should look at it).
Your bad idea of tailgating only needs one example: the tractor to trailer electrical can have a partial failure. No trailer lights. And disc brakes are increasingly common on big trucks. Pair that to awesome sophistication in the computer control of the drivetrain for maximum braking effect. These rigs can slow at a far faster rate than you understand. AND THEY WILL NOT ABSORB ANY OF THE IMPACT OF YOUR VEHICLE. You’ll be hitting a wall at above 30-mph (speed variance).
“Economy” is longest life at lowest cost with greatest reliability.
Tail-gating doesn’t feature. Ever.
The closest you want to come to the rear of a big truck is BEFORE you cannot see both of his side mirrors. No exceptions to speed or traffic. It’s also where you back away.
Tire loss is common. And 100-lb tires disintegrating at speed throw chunks that will come right thru your windshield. No time to react.
Risk Prevention should be your first rule in driving. A commute is just a commute. You chose well or badly in job or home since you haven’t an alternate to driving, now the vehicle bears the cost. Stunt driving isn’t an offset to bad choices
The Following 6 Users Say Thank You to slowmover For This Useful Post:
19bonestock88 (05-29-2019), iikhod (05-28-2019), seifrob (05-28-2019), Shaneajanderson (05-28-2019), Vman455 (05-28-2019), Xist (05-28-2019)
