Old 05-30-2019, 08:13 PM   #8 (permalink)
Shaneajanderson
Redneck Ecomodder
My Insight's was original at 250k also, and was in working order. Good thing too, since they're like $200. The downstream sensor should throw a code if it disagrees with the upstream sensor, and I'm almost certain the Odyssey has a downstream one.
https://www.rockauto.com/en/catalog/...2)+sensor,5132
O2 sensor for my odyssey is like $20. The downstream O2 sensor exists only to see if the catalytic converter is working, so actually it will throw a code if the two agree, which would indicate a catalyst failure
