Old 06-02-2019, 01:19 PM   #331 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Originally Posted by slowmover View Post
Re low-flying obstacles. FINISH first cup of coffee prior to leaving house each morning.
Note the tow rope. Just giving the other guy a hand with a rolling in-gear jump start. Ha! (Glider more likely).
that wasn't a tow rope, it was a mangled piece of tubing. Might be the top rail of a chain link fence, for example.
You don't tow gliders with a plane like that. It's always a high wing, unless it's an air tractor-type strutted low wing crop duster airframe. I spent a few hundred hours towing things like gliders, banners, billboards.
That was the beginning of the end of a very bad day for that pilot. He's already hit something ( the tubing ) and drug a wingtip. As cockeyed as he was, likely a rotten tumbling event after that.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following User Says Thank You to skyking For This Useful Post:
slowmover (06-07-2019)
