Originally Posted by Gasoline Fumes
I'd be more concerned with rust than anything major wearing out. You should stick with Team Suzukiclone, but I'd also like to see what you can do with a Mirage!
Even then, it seems like the metros are fairly easy to do rust repair on. Mine isn't even rusty other than the rockers a little bit, and I've thought about adding some square tube bracing underneath just for a little extra structure. I wonder if that's been done before?
