Originally Posted by vskid3
Impressive numbers from such a beast! What are your tank averages?
The max power available from the battery is probably 20-30kw. I don't fully understand how the Tahoe's transmission/motors work, but if it's like the Prius, power is sometimes sent electrically from one motor to the other rather than through the transmission mechanically. That, and possibly being overbuilt for longevity, is why the motors are so powerful, not for EV mode.
I believe the limit is 60amps, so around 20kw depending on soc.
Edit: sorry, that's the limit to trigger the engine on.
