Old 06-05-2019, 07:14 PM   #29 (permalink)
RustyLugNut
Other than a completely sealed enclosure . . .
Originally Posted by RedDevil View Post
but if a little bit of hydrogen leaks and mixes with the cabin air, that mixture will be explosive from anywhere between 4% and about 85% hydrogen.
You can't smell it or sense it in any other way. A few liters of the mixture could blow the glass out, a whole cabinfull would destroy other cars nearby.
It really isn't safe to carry a homemade hydrogen installation inside the cabin.
. . . it is difficult to achieve a combustible mixture short of a gross failure in the valving or piping. This is due to the rapid rate of diffusion and the fact that it is lighter than air by a large margin. A leak of several liters per second in a car cabin with nothing more than a window cracked open just about eliminates the possibility of reaching 4% for the lower flammability limit.
How do I know this? From personal experience. I work with hydrogen all the time. It's dangers are overblown much like nuclear "waste".
