Old 06-05-2019, 08:15 PM   #79 (permalink)
Daox
The bike got its first ecomod yesterday! Good for essentially no MPG boost, I put in a fancy dancy LED headlight bulb. I noticed my lowbeams were shot on my first trip of the year, so I figured I'd throw in a LED to get a few more lumens which is always welcome on bike.
Fitting it was a bit fun since its pretty tight in the headlight housing.
Old H4 bulb.
New LED H4 bulb.
In order to get enough room, I had to put the electrical connector out the back of the housing.
So, I decided to wrap it up and tape it as best I could to avoid water getting in the connection.
Overall, it'll work good. The high beam doesn't work the greatest, but the low beam works quite well.
ID:	26112   Click image for larger version
ID:	26113   Click image for larger version
ID:	26114   Click image for larger version
ID:	26115   Click image for larger version
The Following User Says Thank You to Daox For This Useful Post:
MetroMPG (06-05-2019)
