Originally Posted by Shaneajanderson
Zombie Thread.
this thread is 11 years old. I see though that no one really stated the obvious. Gasoline is used in lower compression engines because it ignites at a lower temperature than diesel. Anyone who's had a high-rpm detonation bust a crankshaft in two knows this first hand.
In the 11 years since the first posting a LOT has been learned . Your "obvious" information is hardly the answer to the original question. Work by forum members such as Ivey and pgfpro show manipulation of variables can change combustion in a spark ignited gasoline engine. I relish the re-visitation of the subject.
I've run gasoline in a spark ignited engine with 20:1 compression ratio by messing with the "obvious". pgfpro has gone even higher with dynamic ratios exceeding 30:1. How? By running much leaner combustion mixtures than even Honda's Lean-burn engines. Go look up his work on various threads. It's deep reading if you know a thing or two about combustion thermodynamics and thermo-chemistry. Its simply outright fun if you don't.
