Old 06-12-2019, 11:52 AM   #9 (permalink)
redpoint5
90 day: 29.78 mpg (US)
If both are finished out with ducting and all you may need to really open up that air handler to draw mostly air from the lower level. Do something like pull off the return ducting or cut a hole in the return duct next to the air handler.
The downstairs return actually isn't sealed in correctly and pulls air from the wall, mostly bypassing the filter. That's on my list of things to fix.
I wonder how difficult it will be to heat the downstairs in the winter.
