I can confirm that simply running the fan and mixing upstairs/downstairs air goes a long way to keeping the upper level cooler, and the lower level warmer. It heated up a couple degrees in the 20 minutes my air handler wasn't running.
Which would happen automagically in a dome. There, are you happy now?
How does the Ecobee 4 compare to Nest?
https://duckduckgo.com/?q=nest+thermostat+security+issues
