Old 06-18-2019, 12:30 PM   #249 (permalink)
samwichse
Thalmaturge
CHONK - '18 Honda Clarity
Originally Posted by NoD~ View Post
Well, can't win them all... lol. Rest of it got a little warped. Look around the 250 mile mark for it to die. Intake temps were reporting over 140 F. Otherwise, it held 120-130 with ease on hot side, dropped under 100 quickly when adjusted to cold.
Maybe just buy one of these and replace the wax element with your control cable?
https://ecomodder.com/forum/showthre...ake-27400.html
Another option: cut a 2" hole in your cat heat shield and bolt this valve over the hole:
https://www.summitracing.com/parts/o...yABEgL9kvD_BwE
Then run your flex heater hose to a simple PVC wye.
https://www.homedepot.com/p/2-in-PVC...0HD2/100677986
Although that will get you at best a little better than 50% hot air mixed with ambient.
