Old 06-19-2019, 02:51 AM   #2 (permalink)
kach22i
Who knew it would be so complex?
https://aviation.stackexchange.com/q...d-from-weather
One curiosity of this aircraft (afaik, it is the only commercial airliner) is that the main landing gear has no cover:
It is interesting that they didn't even try a partial cover.
http://vintageaviationecho.com/bf109e/
EDIT:
From the same author, claims chevrons are about more controlled vortexes and doesn't even mention sound/frequency node dispersion. More specifically "turbulence amplitude" I suppose it's close enough though.
Keeping MAX quiet - Chevrons
I watched a few other of his videos, good but not going to be 100 percent complete given the limited lengths.
https://www.google.com/url?sa=t&rct=...20MAR68JAfd82u
The chevron jet intensifies both the R2222 and R3333 cross– correlations within 2 jet diameters of the jet exit. The amplitude, length and time scales of the cross–correlations of a LES velocity field are investigated as functions of position and are found to be proportional to the turbulence amplitude, length and time scales that are determined from a Reynolds Averaged Navier–Stokes (RANS) calculation.
Back to wheels:
The 737 air-frame goes back to 1968, I really doubt that a clean sheet design would ever go back to a similar solution.
aerohead (06-19-2019)
