Old 06-19-2019, 02:07 PM   #6 (permalink)
BongoBennie
lead foot
Originally Posted by California98Civic View Post
I'm guessing that you're planning to tune the ECU fuel maps so that you can run really lean at part throttle at freeway speeds.
KPro V4 w E85 sensor is in for sure, will also be open loop lean burn for sure. Looking at staged injectors/bi fuels (87/E85/CNG?) but remembering this is a hobby and and expensive one so all in good time. Keep in mind if and when gas his $5 or even $10 per gallon all this crazy talk ain't so crazy. I had a K24A2 EP3 with zero eco interests until it was a $50 fill up every 3 days, it's how I met y'all.
2001 Insight 11.5:1 K20a3 turbo / 04 Element
The Following User Says Thank You to BongoBennie For This Useful Post:
Ecky (06-19-2019)
