Originally Posted by Taylor95
My vents are here! Now it is just a matter of when I'll have time to cut into my hood. Results should be here in the next few weeks or so.
Be mindful of the bracing under there.I chose to make the penetrations only where there wasn't any ribbing,to maintain the stiffness of the panel.
Tufting will reveal areas of accelerated flow(typically near the A-Pillars,with tufts closer together),these represent lower pressure for scavenging.
Any placement will be at a lower pressure than the grilles inlet,so the air is gonna come out regardless.
