Old 06-23-2019, 11:04 PM   #5 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by straight5 View Post
Thanks for the reminder. I don't haul anything with
If I put p rated on the front and LT in the back, then I can't rotate the tires.
If they are the same size you can rotate but you need to take care of when and how long, on my 2wd trucks not being able to rotate wasn’t a big deal but YMMV
NON LT tires need to be inflated fully above the door placard on a truck or they tend to blow sidewalls as an FYI
Even when they are rated for your loads, sucks but over 30 years of playing that game it just seems to work that way.
If you want buy a set of LRR tires off the discount rack at Walland and test them all around
If your truck is light enough they might still provide good service the worst that will happen is a prematurely blown tire
Good Luck
