Originally Posted by Shaneajanderson
Your S10 certainly doesn't need LT tires, most full size half tons don't even call for LT tires, at least the years I'm familiar with. My 94 F150 4wd stock tire size is a P235/75/15XL. The XL is a slightly higher load rating than without the XL designation, but it's still a P tire, only 6-plies.
I would never put an LT tires on something as small as an S10, because if you're looking to carry that kind of weight you need something bigger, or you will be way overloaded.
In order for the Post Office's smallish mail trucks to have a 1000 pound cargo ability, they need LT tires. We tried to order snow tires for them and the only available tires in the size were P series and thus would be under the weight capacity by 30 pounds per tire. So no snow (pun intended) tires on the 300,000 mail trucks in the US. Those smaller tires, in this case a 14" wheel, really aren't that high of a rating when going to LT, and the mail truck is basically a Chevy S10 with an aluminum body on it. Oh and the dedicated snow tires cost 1/3 the price of the LT tires we buy (Goodyear Wrangler almost $300 each because why wouldn't a government agency use a tire size/spec nobody else on the planet is using?) Even better we get to run chains in the winter that cost $75 a set and last 2 weeks tops tearing up the roads.
On a side note, I don't think the LT tires are necessarily that much worse RR, but by far most LT tires also add aggressive tread designs which will be bad for RR.
