Old 06-25-2019, 12:34 AM   #220 (permalink)
mpg_numbers_guy
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
Well I've ordered a used HRP-600-15 off of ebay for $42.99 as well as the 3-phase rectifier, so we'll see how this goes. I'll look into bypassing the psu's internal rectifier if the voltage isn't enough as is at low rpm driving. I'll order a fan once I get it installed and get the car back on the road.
Thinking of going with a manual kill switch rather than using a relay. That way maybe I can dinker with doing a little bit of "alternator-less" driving, and more importantly turn off the PSU at strategic times if it starts to get hot. A basic 12v battery kill switch like this should work, hooked up to the ground lead coming out of the meanwell.
This should make rebuilding and recarpeting the rear a bit easier with not having to work around the stock DC-DC converter, but I wish it had happened on my timing, not as a result of one little broken bolt.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
