Old 06-25-2019, 11:17 PM   #44 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Forget about the surface texture; if the belt was moving relative to the air, there would still be a no-slip condition between the flow and the belt surface, which is why a boundary layer forms in the first place.
The airspeed and belt speed are the same; there is no acceleration of air by the belt, and no boundary layer forms between the belt and flow. This is what happens to a car on the road; to accurately represent that, you must have one boundary layer under the car, between the car underbody and the airflow. A second boundary layer between the ground and flow results in a u-shaped velocity gradient.
Elevating a car in a wind tunnel is a common practice for correcting for both wheel drag when using stationary wheels and floor boundary layer when using a fixed floor.
I'm travelling right now, but when I get home next week I can post the relevant pages from some textbooks, including Hucho's Aerodynamics of Road Vehicles, that might explain better.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
aerohead (06-26-2019)
