The latest Explorer is light years away from its predecessors. And would make an excellent tow vehicle if set up for street performance. The police-spec models are quite capable.
Trailer weight isn’t ever the burden. It’s trailer shape which matters. A fully aero travel trailer can handle the REAL problem of highway travel and that is adverse winds. Tow rigs are involved in loss-of-control accidents due to natural or man-made sudden gusts, AND the driver incorrectly dialing in too much steering. It all happens and is over in 2-3 seconds.
1). Step One
With driver only and gear kept permanently aboard (till the day it’s sold) Scale the vehiccke after topping off the fuel tank at a travel center. (CAT SCALE phone app). Go inside to the fuel desk for the paper copy.
Against the door sticker showing AXLE/WHEEL/TIRE limits, note the range remaining. (Post it)
From this info is how one sets a weight distribution hitch.
Example: a 800-lb trailer tongue weight will — after correct distribution — be relected on a scale reading as approximately under 300-lbs to the front axle; a little over 300-lbs to the rear axle and 200+/lbs to the trailer axles.
But, no, despite acres of ignorance this IS NOT about “Payload”. Load the vehicle as you will with 800-lbs and the scale will show the bulk of it o the rear axle. The only legal limits are the tire/wheel/axle Load limits. .
The “best” tow vehicles have a VERY short rear axle to hitch ball distance. As well, fully independent suspension and low center of gravity. All of which describes the current Explorer.
Agreed that the older ones were terrible in every role above 35-mph. Dump it for something worth using.
The current ones have more than enough power to pull a truly aero trailer up to 23’ or so without issues.
A pickup is nothing but a high risk vehicle.
There are plenty of trailer choices. An Airstream of 10-15 years of age has shed nearly all depreciation. From there, prices again start to rise. It shouldn’t need much of anything g given covered storage and regular maintenance. The other upmarket brands have been out of production 20-years or more, BUT will cost less and need less than any Airstream of comparable age & condition.
How the trailer will be used, the distances contemplated, are more to the point of what’s important. The tow vehicle is NOT very important as so many vehicles are fit subjects.
It’s the trailer that matters.
