Old 07-01-2019, 08:58 AM   #8 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Do you know the fuel rail pressures that those flow rates are set at? If your ranger is flowing 18#/hr of fuel at maybe 40psig while the 12 hole injectors are flowing 23#/hr at 60psig, then they're not necessarily a larger injector.
It's used a lot in tuning if you need more fuel you bump up the fuel pressure to make up for smaller injectors.
Conversely, if you need less fuel you turn down the fuel pressure
The Following User Says Thank You to ksa8907 For This Useful Post:
hat_man (07-06-2019)
