Old 07-01-2019, 08:11 PM   #73 (permalink)
EcoCivic
You can just use a swamp cooler.
Let almost all the mineral build up and corrosion happen to the swamp cooler.
BUT it only really works if you have a mechanical txv and will work amazingly if you have a txv and variable speed compressor.
So you are saying run the refrigerant through the condenser and then through a swamp cooler to cool it further?
