Originally Posted by teoman
https://newatlas.com/mistbox-air-con...ecooler/38139/
That is a commercial system that increases the efficiency of A/C systems by using evaporative cooling by means of water misting the intake air.
Here is an educated discussion on the matter:
https://hvac-talk.com/vbb/showthread...condenser-unit
The main concearn is rusting the coils and getting mineral deposits.
The key point seems to be having the spray as far away from the condenser as possible.
Shouldn’t automotive systems be more resilient ot road grime and debris gathering on the condenser.
not with distilled water there is no gases in the water. that is why they insta boil when you drop a sugar cube in super heated distilled water
