Originally Posted by teoman
Do you mean minerals?
Because i am pretty sure distilled water contains nitrogen and oxygen in it.
Our bodies contain about 1.5 liters of nitrogen gas dissolved in the blood and tissues.
no distilled water does not boil because there is nothing to cause it to happen
it's straight h2o..
if it had nitrogen and oxygen (dissolved gases ) it would boil..those are called impurities .. like co2 makes bubbles in soda it has dissolved co2 gas..
your car cooling system uses distilled water mixed with coolant so if it's safe for the inside it's safe for the out side
(i would worry about scale building up and decreasing the efficiency of the cooling unit if TAP water is used)
