Originally Posted by jcp123
I think there’s a bit bit of over-analyzing goin on now. I still stand behind TFLTruck, but you can’t have it all. Pick a midrange tow vehicle, and go roll. If you gotta tow, I’d rather you go overkill than get killed. Towing is a kinda serious business.
Bad advice is bad advice. Source unimportant.
What sells pickups is what you’re reading.
The heavier and longer and taller the tow vehicle (etcetera) the worse the potential outcome.
It’s design that matters.
Unit body is superior to body on frame, for example.
Low profile wide tires beat narrow pickup tires any day. Etc.
The literal best tow vehicle is a Porsche Cayenne Turbo. The EcoModder choice would be the circa 2006 non-emission mid-size Mercedes turbodiesel sedan.
As before, fit the TV to the TT. Cart before the horse, in this sense.
