Old 07-03-2019, 09:39 AM   #23 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
You have too many variables right now to optimize to a solution. You are spot on about the legality and making sure the weight ratings and numbers are correct for what you are doing. People who don't wear the scars of something gone awry often don't understand. Things are different now than they were when I grew up.
For context I presently have:
2001 Chevy 2500HD 8.1L Allison 4x4 ECSB (heavy towing/hauling)
9200 GVWR; 22,000 GCVWR; 15K+ Tow Rating
1994 GMC K2500 Suburban 6.5L Diesel NV4500 4x4 (project)
8600 GVWR; 7500 Tow Rating
1999 4Runner V6 5spd 4x4
5000 Tow Rating
I am very happy with all of them, they each perform their functions well. I have "offroaded" all of them to some extent, nature of being out in the sticks needing to get things done.
If you really want 1600lbs+ payload you are looking at 3/4 or 1 ton. Good job for realizing you cant tow the max rating with tons of payload, that is lost on most people. You don't need the weight distributing hitch when towing with an appropriately sized vehicle.
Don't put too much stock in the crash test ratings for very large vehicles, as they discount mass by crashing into immovable objects. For the vast majority of situations mass is a big factor. All rear crash test data is performed without a tow hitch, adding a tow hitch (rigid frame connection) 100% renders all that data useless. (get a Superbumper)
If you are looking to do hardcore technical trails you should consider doing a tow pig pulling a toyhauler. Forest service roads and easy to moderate trails can be tackled by a full size.
GMT400 2500 stuff is not compatible with GMT400 1500 stuff. GM did produce a GMT400 2500LD (light duty) which means they took a half ton and called it a 3/4 ton. (I owned one.) Nothing special about it besides 7200 GVWR. Real GMT400 3/4 tons had 8600 GVWR. Had a 14 bolt semi float axle, but so did many of the half tons. IFS is exactly the same as half ton, not interchangeable with real 3/4 ton IFS.
In the Chevy/GMC world, GMT400 is at the bottom of it's depreciation curve. GMT800 is barely ahead of it. Parts are cheap. I find the NV4500 equipped trucks enjoyable to drive.
Whats the approximate budget? Newer trucks are having increased payload to meet the SAE towing requirements, older trucks not so much.
The Following User Says Thank You to aardvarcus For This Useful Post:
slowmover (07-05-2019)
