Old 07-12-2019, 01:19 PM   #3 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Most plating is almost entirely ineffective. Heat cycles will draw in moisture and cause it to flake off, possibly worse than bare since the plating will hold in the moisture.
Powder coating might work better but again, if moisture can get under it... you're done.
The Following User Says Thank You to ksa8907 For This Useful Post:
Xist (07-15-2019)
