Old 07-12-2019, 11:10 PM   #3 (permalink)
TexasCotton
TexasThunder Avg MPG 54 - '08 Toyota Prius Base
Originally Posted by mpg_numbers_guy View Post
The stock Prius rims on the 2nd gen are already only 14lbs if I remember correctly. Pretty light for a 15" rim.
Newer Prius rims are slightly heavier I think but are also available in 15" with the same bolt pattern.
You are very much and accurately correct in your statement.
However, I seek lighter there is one or two lighter ones at 9 pounds I believe the model is Rays Eco JDM and maybe PIAA...going for crazy money at 500-600 a wheel/rim just found them listed never found them for sale...t
The Prius C/ Yaris have a 4-100 lug pattern 15 rim and have more available rims like the Enkei RFP at 9lbs
The other issue is a lot of aftermarket and OEM do no state rim physical weight at all
