Old 07-14-2019, 01:39 AM   #249 (permalink)
mpg_numbers_guy
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
Yea, not sure what was going on there on the rear brakes. The brake worked okay - not perfect - when I bought the car, but has slowly gotten worse, probably as the wires have moved around from the driver's side not being connected.
No boards permanently installed yet on the rear rebuild; been working on fabricating them and getting a few frame pieces built. Got a squeak to locate tomorrow, probably the foam board rubbing against the kill switch that got moved a bit when test fitting plywood behind it. Waiting on the parking lever to arrive to fix the e-brake. Also had to order a part for the S2000 e-brake install - I'll update on that when it's installed. Both parts should get here Monday.
Passenger side test fit:
Driver's side test fit:
Hole cut for Meanwell area exhaust fan:
Nothing's attached yet, just building the pieces and test fitting. And waiting on stuff to arrive.
ID:	26388   Click image for larger version
ID:	26389   Click image for larger version
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
