Old 07-14-2019, 03:44 AM   #227 (permalink)
19bonestock88
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
Originally Posted by mpg_numbers_guy View Post
If it's P0420 then replacing the other piping won't fix it; it needs a replacement catalytic. You could probably try cleaning it too. RockAuto has good prices on aftermarket catalytics, or you could just straight pipe it with an O2 fooler.
WV doesn’t do any emissions testing, and part of the build involves increasing power to make better pulse/glide length ratio, so I planned on a cat delete and upgraded exhaust... in addition, I can have the exhaust guy take special care to tuck the pipe up tight to the underbody and my new muffler is flatter than the stock one, so I should be able to make a nicer rear diffuser without having to cut out around part of the muffler...
My current Ecotec project...
My last Ecotec project...
