That looks super clean. I've been experimenting with doing this under my Volt however I have been trying to find a large enough piece of coroplast or something to use under the car. I tried an initial prototype of my own with cardboard which ended up coming loose after some time (nothing was near the exhaust in case you were wondering). Have you noticed any improvement in mileage? Also, how much did this project cost? I had not thought about using aluminum diamond plate but I might consider it if is not too expensive.
